Some render 3#
Some render 3#
Richardo rise up level...so I put some my render which I did not show before.
Greetings for Piotrek from http://www.pandm-studio.com/ :wink:
azman_821009
Re: Some render 3#
Post by azman_821009 »
Awesome!! Love it.. How can i get this kind of rendering? If you don't mind. :wink:
Azmen
Re: Some render 3#
Post by salvatore »
:shock: :shock:
I cry! :D
perfect impossible amazin renders!
Re: Some render 3#
azman_821009 wrote:Awesome!! Love it.. How can i get this kind of rendering? If you don't mind. :wink:
Azmen
Lumi panels in windows + small lumi panels from ceiling (total in scene around 20 sources of light) + good colours for lumi (cold/warm) + good tonemaping + good texturing + good PS...that is it.
cruisermori
Re: Some render 3#
Post by cruisermori »
:o Superb work. Do you use Photon or Light map mode?
azman_821009
Re: Some render 3#
Azmen
Thanks for sharing.. :wink:
Anyway if you put almost 20 sources of light, how long for the render time?
Azmen
jnom
Re: Some render 3#
Post by jnom »
Ah so you're back to using lumipanels? Arealights had good contact shadow but noisy and longer render time.
ideart
Re: Some render 3#
Post by ideart »
Perhaps we should make a contest project named "do it like Januz". Thank you for your inspiring eye candy.
sotto3d.com
Re: Some render 3#
cruisermori wrote::o Superb work. Do you use Photon or Light map mode?
always Lightmap with global Receive.
Re: Some render 3#
Azmen[/quote]
Azmen[/quote]
Depends from scene. sometime 10 sometimes 40 and more. More lights means better effect but harder to control balance of light (need a lot training where, how strong, what color) ..tonemaping is never enough for render, so always I support tonemaping by extra lights (all ideas are welcome). I do not use Area Light - they are not full support by Kray (we do not have Area Lights done for Kray, they are just lightwave sources of light...and maybe in future will be shader for that , which will increase speed and decrease noise). I suggest lumi poly everywhere as is possible and good tonemaping.
