Lrage images...
Nemesis CGI
Lrage images...
Post by Nemesis CGI »
Just ran into my first real problem. I have to render out a scene at 5200x2000, trouble is when KRay starts to render it crashes. The scene uses around 600MB I should add.
To get around this I've use Limited-region with the borderless option. Thankfully this looks like it's working.
Is this a know limit?
Shaun.
Captain Obvious
Post by Captain Obvious »
Largest image I've rendered so far is approximately 5000 by 3000 pixels. I did have tons of issues, though; it basically only worked on machines with 3 gigs or more of memory, and the /3GB switch thingie, as well as 64-bit machines (running 32-bit LW).
Nemesis CGI
Doh, though that might be the case.
I've had to give each tile a large overlap as the colour can differ slightly for each tile. Not a major problem. At least they line up.
Shaun.
