I got a scene that is not that complex... but it allows me to exit LW instantly by pressing any KRAY render button.
Are there any restrictions that I'm unaware of? I'll try to attach the scene the moment I get it exported 'and' unrenderable, since it seems to be a little tricky to recreate.
The objects alone render fine... textured and untextured (I need the override textures function for this project anyway). I found some errors here and there, that I corrected, and also cleaned any ngons, double sideds or similar. Then I import the light setup from the crashscene... not definitely a problem. Then the cameras... and I'd love to say that is the problem. But I tried it the other was round, too (first cameras, then light setup). I also recreated the lights from scratch, I exported the camera motion and applied it to a new one (whatever that should have solved... I was desparate.
Is there a difference between LW and KRAY regarding this case: I did not duplicate the objects (except for backup), I simply (for fast testing) deleted the images from the image editor and removed the textures from the corresponding Layers (color channel only). Does Kray maybe still access the original objects with all those information? I recall some version, where KRAY needed to save the LW scene and objects before rendering...
Anyway. At the moment I'm back to the LW rendering (which annoys me a little... nargh!), but hopefully my worries can be solved here?!?
Have a nice weekend...
Greets.
Oliver.
