Plugin KrayFrame failed to Start
except
Post by except »
I just received my Kray licence (hurray!)...
But unlike the demo version... after normally removing that one and putting the new one in, the interface (krayoptions) works, but when I press render frame I get 'Plugin KrayFrame failed to start'.
This is on 9.2 OB13.
erwin zwart
Re: Plugin KrayFrame failed to Start
Post by erwin zwart »
except wrote:I just received my Kray licence (hurray!)...
congrats! Did you get kray 1.7 OB2?
Did you remove all old kray related .ls files too? Normally you should copy kray.p in the root of Plugins and kray.ls in the lscripts subdir there. In that subdir you should have the Data dir with the lw_about.tga file. I use this successfully from 7.5 to 9.2 OB13, my main LW version is still 8.5 but I use 9.2 for some modelling stuff and ofcourse testing the new render stuff of that, nice progress there last versions, reflection blur, MB and AA looks very nice now.
except
Post by except »
Well. It's still not working.
the demo works fine, OB2 doesn't work at all.
Tried everything under the sun.
Perhaps your Kray.p is damaged. Try to download it again. Make sure you install Kray.p that is in LW8.x 9.2 folder.
except
Post by except »
Yep, that was it. Downloaded it again, copied over it, now it works.
Sort of. It crashes immediately when trying to render one of my scenes.
I'll try to render something else.
Are there any known crash-bugs known?
Yes. You shoul check 1.7 Open beta forum section.
