As I have a little time now I thought it would be good idea to start LW trail
When rendering my basic EXT setup scene however I get error in render window.
Looks like something with photonmuliplier setting but I can't seem to find where?
Kray 2.59
edit:
I replaced KrayPhySky.lsc with 2.58 one and error is gone?
LW 2015 render error
Re: LW 2015 render error
this error too lw 11.6.3 - changed physical lws it's ok
Please post scene here with problem (can be even empty scene).
Also open empty layout and start Kray to check it is always or in some situations (for example you loaded very old scene). I suspect some incompatibility in LW SDK but I am not coder so best idea is to catch error in basic scene and upload it here.
There is one trick what I do always. When I get errors (very rare) I just shoot down LW open fresh Layout and Load Items from Scene WITHOUT Kray settings.
So I open scene without Kray and I add NEW fresh settings (You have to update setting in Kray manually - do not import settings!) ...always helps
now i can't post scene because i've save on it...but change lws i'vent error too in old scene.
today i've download kray 2.59 - open old scene (yesterday) and this is the physky error.
if change physky.lws with this: http://www.kraytracing.com/joomla/forum ... =viewtopic
open scene is ok!
open scene is ok!
btwnico wrote:today i've download kray 2.59 - open old scene (yesterday) and this is the physky error.
open scene is ok!
Difference is only in command line.
Actually I do not use Physky in K2. Gives bad colours (old system) ...but Physky in K3 this is masterpiece
