Clip Map bug
artzgodka
Clip Map bug
Post by artzgodka »
I on two objects do different completely Clip Map
and Kray it renders it even-Stephen
why
I greet
az
clip.rar
(24.54 KiB) Downloaded 380 times
Post by silverlw »
There is issues with clipmaps wich already have been reported as bugs so G is looking at it. Probably solved soon.
artzgodka
Post by artzgodka »
grand merci
I greet
pixym
Post by pixym »
"grand merci"
Do you speak french?
Kray render transparent object very quickly.
I have removed the clip map channel and move it to the surface transparency channel of my objects.
Eddy MARILLAT
PIXYM
artzgodka
Post by artzgodka »
I am sorry for my English
it is catastrophic :oops:
it is not the same
when I make how you write, and i will add reflection channel
kray renders this what it should be invisible
