Latest white bathroom render
2400px X 1400px 1hr 36 mins .....
Btw;
Can anyone please teach me how to create sharp edge shadow for the corner? Bcz most of my renders
Something like Ambient Occlusion effect, I know AO is not apart of realistic render, but I've been trying hard to achieve dark corner effect but not results....
White Bathroom
Re: White Bathroom
What CPU? Because if it is Dual Xeon then time should be under 1h with QMC and HQ setup for this scene (!) This is not complicate scene to calculate...so maybe even under 30 min.jonathlee wrote:Latest white bathroom render
This is very difficult question or maybe not.Can anyone please teach me how to create sharp edge shadow for the corner? Bcz most of my renders
The only system which offer this is Path Tracing or QMC system render.
Please forget about Ambient Occlusion (this is old technology in my opinion which support imperfections of render engines or bad set up. In real world it doesn`t exist same as specular effect) Of course OCC is popular now , especially in GPU renders (Octane) because without this you will never render scene with full Path Tracing system with minimum 5-8 bounce light system...it must be "cheated" by Occlusion and another systems. Personally I am fun of pure rendering and I never used OCC or specular.
The best pure system rendering is in Maxwell which I very admire but speed of it is a complete misunderstanding.
So solution for You: QMC with Photon Mapping
Re: White Bathroom
Thank you Janusz for the explanation.
I'm using single Xeon 2.6 quad. May it is because I have many glass surface (different layer with unseen by radiosity), now testing with QMC.
Re: White Bathroom
...so this time is very good. In QMC you should get twice longer time render minimum but...jonathlee wrote:Thank you Janusz for the explanation.
- with GI accuracy you almost near Path Tracing (remember Kray use extra Path Tracing photons to correct GI in corners)
- this is simple scene so it will be longer with QMC but from my tests I notice: with very heavy scenes it is much better use QMC because time render speed is almost the same so is no doubt to use this! (I talk about minimum 40 Area lights, over half Giga data scene, many instances) The amount of ray tracing calculations starting be very big and better is to switch to QMC.
- now is impossible avoid glass problem in Kray It must be recurse 12 ...We must wait for K3.0 for special shader. But reflection problem you can easy solve by Nodes and reducing there amount of recurse to maximum 3. It helps with bathroom tiles, sink metal (generally with opposite and high reflection surfaces)
- everything above will change for positive things in K3.0
Re: White Bathroom
In terms of render time I found first render and second render (QMC), time is slightly longer with QMC. But the shadow seems to be better, plus I love noise. So, QMC works well, but need to spend more time to balance the settings.
The render took so long is because of the glass material (Fast Fresnel), camera was placed behind glass area.
Btw; the K3.0 shader for glass is using node? This is since I really have no experience in using Node....
Re: White Bathroom
There is not "seems"jonathlee wrote:In terms of render time I found first render and second render (QMC), time is slightly longer with QMC. But the shadow seems to be better
The level which I use in FG tab is min/max 50/300. This is minimum. Later you can clean noise. Also then bigger image then better quality and easier to clean noise.plus I love noise. So, QMC works well, but need to spend more time to balance the settings.
There is no compromise when we talk about qualityThe render took so long is because of the glass material (Fast Fresnel), camera was placed behind glass area.
It will be shader or directly from engine special part which better control physics of glass.Btw; the K3.0 shader for glass is using node? This is since I really have no experience in using Node....
No Nodes = no good quality.
