any trick to get only shadow from kray buffer or i dont know i went to get only shadow from kray render how pls thnx .
finally i use camera projection map on the ground to get the gi from hdr on the ground :'( .
Any new buffer for kray 2.51 to get shadow only pls .
Last edited by Keraressi Abdelkarim on Wed Jul 10, 2013 2:07 am, edited 1 time in total.
Re: Any new buffer for kray 2.51 to get shadow only pls .
and if i use for ground i use texture front projection lw crash when i do render with Kray any help pls
i use projection on the ground image projection + select corrent camera lw and kray crash :'(
Ifound bug with kray if u have many camera for exmple camera 1 camera 2 ex...... to 13 as i did .
if u select camera 13 on ground surfaces as projection map image kray crash .
to solve this . u need to delete all camera and use one camera on the scn .
matte the car and use a white ground, should give you a shadowpass...
thnx man .
can u give us small exmple pls
thnx a lot .
thnx a lot .
