hy guys, for anim of camera i've used GI Mode in Load and i've see BAKE ONLY TAB.
What's the function of BAKE ONLY? for anim only camera is convenient use it?
BAKE ONLY save GI Final Gathering samples to file. So all functions are OFF: AA, blurr, reflection - because You do not need them. You should use minimum 2 passes render for that.
Also before that You can use STEP every 20-30th frame in GENERAL Layout options (if camera is slow) - this will save time.
After when whole BAKE procedures is done You can switch to normal render and change STEP frame to one with ONE PASS render. If You lost I can make short video tutorial.
Here short tutorial. I moved it also to KrayWiki page. Sorry for no commentary but my USB camera doesn`t work with recording software properly (I have noise in background) I have to buy with jack connector....
