Kray and LW 11.5 Crash
- ryste3d.com
When loading a LW 11.03 scene into LW 11.5 Kray will crash shortly after hitting the render button?
Re: Kray and LW 11.5 Crash
Can You post scene (only lws+obj)?ryste3d.com wrote:Hi,
- ryste3d.com
Hi Janusz,
Well all the objects are professional stuff (no legal to share) but can I send it to your personal mail adress?
You have all info in my profileryste3d.com wrote:Hi Janusz,
janusz.biela@gmail.com
or
skype: biela1972
Problem solve: Selected Vertex Normal Map in Surface Editor make crash in Kray. Should be none there. This problem appeared in LW 11.5.
ok thnx jansuz
i've a problem using sk portal + sun....when i use sk portal kray go in error render
SK portals from LW are not done for Kray.nico wrote:i've a problem using sk portal + sun....when i use sk portal kray go in error render![]()
yesterday i've used sk portals (dpont) + sun with render in kray for testing and work.Janusz Biela wrote:SK portals from LW are not done for Kray.
today on pc only for render and crash!!!
thank's
nico wrote:yesterday i've used sk portals (dpont) + sun with render in kray for testing and work.Janusz Biela wrote:SK portals from LW are not done for Kray.
today on pc only for render and crash!!!so will use physical sky and lumipanel
thank's
Yes . Try deal with this until K3.0. I use now only physical sky and sometimes lumi (also Area Lights are interpolated, why they are slow and noise ) Do not worry in K3.0 will be no compromises
