tonemap blend
azman_821009
tonemap blend
hey guys.
how to use a tonemap blend? where can i get the tutorial for it?
Thanks..
Azmen
Thanks..
Azmen
azman_821009
Re: tonemap blend
I can't go thru kray wiki link in firefox. I think jure, you should fix this link on firefox.
Thanks.
Thanks.
Re: tonemap blend
On which link are you clicking exactly?azman_821009 wrote:I can't go thru kray wiki link in firefox. I think jure, you should fix this link on firefox.
Thanks.
azman_821009
Re: tonemap blend
'learn' tab on the top..only IE can open it but not in firefox..
Re: tonemap blend
here example.
It is easy:
1. LINEAR TONEMAP in Kray General tab (means OFF)
2. ON QuickLWF , ON Tonemap Blend
3. BLENDING in Tonemap Blend - 20% means: 80% Exponential/20% LWF Gamma (keep this between 20-50%)
btw in those windows You have a lot keys for good renders...remember also about good light in scenes
It is easy:
azman_821009
Re: tonemap blend
Thanks Janusz..So i need to play also for the Quick LWF?
Re: tonemap blend
...You have too (this tool correct colors in tonemaping)azman_821009 wrote:Thanks Janusz..So i need to play also for the Quick LWF?
Re: tonemap blend
It works fine here in firefox.azman_821009 wrote:'learn' tab on the top..only IE can open it but not in firefox..
azman_821009
Re: tonemap blend
Here is the printscreen in my firefox browser.jure wrote:It works fine here in firefox.azman_821009 wrote:'learn' tab on the top..only IE can open it but not in firefox..
Re: tonemap blend
azman_821009 wrote:Here is the printscreen in my firefox browser.jure wrote:It works fine here in firefox.azman_821009 wrote:'learn' tab on the top..only IE can open it but not in firefox..
I had this error before . problem was with firefox and his plugins (java, flash?). Reinstall firefox and plugins.
