Hi guys,
I found out the easy way to animate leaves using displacement in object properties. In LW native render it work perfectly ( I follow exactly as in tutorial) then I try rendering in kray and used kray_instance but the output no animated leaves. Does kray wont work with displacement in object properties?
Thanks..
Azmen
Displacement object use Kray_Instance
Re: Displacement object use Kray_Instance
It should work. Check that you have "Allow animation" checked in general tab.
