I have tried rendering instances with X scale value set to -100%min -100%max but it has no effect.
Z and Y value seems to render ok.
Even normaal mirrored objects dont render mirrored.
Am I missing something here ?
mirrored objects dont render mirrored?
keeejreeej
keeejreeej
Re: mirrored objects dont render mirrored?
correction, normal mirrored object render out fine (mirrored) but is it possible to render instances mirrored?
If you use nulls to make instances then try making those nulls negative scale...
keeejreeej
Already tried that, doesn't work.
Changing instance scale or null scale only works for Y and Z scale ?
edit: newer tests show that instance X scale has no effect while Z scale scales in X and Z direction.
LW 9.6 Win7 Kray 2.2 build 1211
No it should work for X also, if it's not then it must be a bug.keeejreeej wrote:Already tried that, doesn't work.
keeejreeej
Maybe others can confirm?
