Hi everyone,
I just want to know the 'Non-Planar' support in Kray rendering?
Read the tutorial about DOF and if I want to used a DOF, the camera from LW must change to Classic. How about if I want used a Real Lens camera or Advance Camera?
How can I make a Motion Blur in Kray? Also I need to choose the Classic camera?
Can I make a clay render using Kray without edit the existing texture on the objects?
Thanks.
Azmen
						Non-Planar support in Kray, DOF & Motion Blur.
				azman_821009
Re: Non-Planar support in Kray, DOF & Motion Blur.
its supported.azman_821009 wrote:Hi everyone,
you can use any camera. Just make sure you use FSAA in sampling tab.azman_821009 wrote:
Yes. use kray override plugin.azman_821009 wrote: Can I make a clay render using Kray without edit the existing texture on the objects?
Thanks.
Azmen
				azman_821009
HI Jure,
I was trying used a FSAA in sampling tab. It took long time to render more than an hour. It's that normal?
Anyway thanks for the answered for Clay-render & Non-planar.
Thanks.
Azmen
 Thanks.
Azmen
Yes it's normal that FSAA is slower than non-FSAA.azman_821009 wrote:HI Jure,
Thanks.
Azmen
