IES lights overblown
thomas
Post by thomas »
Hi!
Another day, another question of mine - just learning Kray :) .
1) I want to include IES-lights in a scene but in all my setups ( not only this specific scene ) my IES lights are completely overblown. I don't know if there a whole lot to do about this because as I understand it IES lights are just correct the way they are and all you can do is change exposure or use another IES profile.
2) What does the size of a light do with IES lights in LightWave native renderer? I've noticed that this changes something about the sharpness of the light-web. Does this do something in Kray as well or not?
3) If I'm not mistaken there is only two things you can adjust for using Kray with IES-lights: the IES profile used and the light intensity, right?
p.s. I would love to show you some of my work instead of only asking questions, but since this is under non-disclosure it's impossible for me!
Thanks!
Thomas
Re: IES lights overblown
thomas wrote:Hi!
It's just like with any other light - if intensity is high and light close to the wall then that part will get overexposed. The issue with IES lights is more pronounced because those lights have a very focused area of where the light is emitted to. You can overcome this problem somewhat by using light power multiplier.
thomas wrote: 2) What does the size of a light do with IES lights in LightWave native renderer? I've noticed that this changes something about the sharpness of the light-web. Does this do something in Kray as well or not?
I'm not sure what size you mean.
thomas wrote: 3) If I'm not mistaken there is only two things you can adjust for using Kray with IES-lights: the IES profile used and the light intensity, right?
Thanks!
Thomas
Yes that is correct.
thomas
Post by thomas »
Hi Jure,
Thanks for the answers, fast as always! What I meant with the size parameter of IES lights was that in the LightWave Renderer ( not in Kray ) IES lights render differently when you change the SIZE parameter ( not in the Lights properties, but just in Lay-Out like the move and rotate parameters ). The IES light web becomes blurrier when you make the lights bigger - the intensity and distance stay the same. I wondered if this played a role in Kray renders as well.
thanks!
thomas
thomas wrote:Hi Jure,
thanks!
thomas
If it works in LW then I think it should in Kray too. But honestly I never tried that because I didn't know about this behavior.
