Plug-ins troubles
Alexos
Plug-ins troubles
Post by Alexos »
For some reason the K-ray master plug-ins keep giving me problems: every now and then activating one of them (quick LWF today, but it was physky the last time) through the K-ray interface will cause LW to crash - but only then; if I add them via master plug-ins they work flawlessly.
I've already physically deleted everything, removed the plug-ins and lscripts, re-installed and re-added; four times now. It works for a few days and then goes kablooie again, leaving me completely mystified. Any ideas?
ADP.
Re: Plug-ins troubles
What are your system spec? Did you try cleaning config files?
Alexos
Post by Alexos »
jure wrote:What are your system spec? Did you try cleaning config files?
Dual Xeon E5410, Xp32 SP3 and yes, I did delete the .cfg and let LW recreate it. Funny thing: I did a "load from scene" (like you suggested in that other thread - thank you) and grabbed the k-ray master plug-ins; it loaded them all *except* quickLWF (the one that's causing the crashes), which remained disabled - enabling it of course caused a crash. I then replaced kray.p and it crashed with every single master plug-in; I replaced all the lscripts as well and now it works... just like the other time. This is rather weird. Gonna have to remember to thread carefully there...
ADP.
