renders of a architectural work project.
are renders to show the idea to client
leaving recent work
Re: leaving recent work
I think you could improve the scene if you added different colors to your lights. Now all looks too white. Also lights are pure white - proabably because of strong luminosity? You can fix this problem by using low luminosity but adding KrayPhotonMultiplier shader and increasing Luminosity power multiplier. You will get same light intensity but lights won't look pure white.
hi jure,
the choice of lighting so white is desired.
the apartment is very bright and a potion lamps wanted the white ice.
in fact, the parquet is much clearer and the lamps have a warmer tone.
