render preset
albertos2008
render preset
hi to all..
there's a way to put also my personal preset under the "render preset" menù?
just saving configuration is too complicated...
thanks!..
Alberto
thanks!..
Alberto
Re: render preset
Not without modifying Kray script. But if you know how to lscript then it should be easy.albertos2008 wrote:hi to all..
thanks!..
Alberto
You can use Load/save buttons to do the same though...
albertos2008
Re: render preset
I will try the hard-way (I repeat "try")...
can I use the notepad?..
thanks!..
thanks!..
Re: render preset
Yes, I recomend notepad++ though.albertos2008 wrote:I will try the hard-way (I repeat "try")...
thanks!..
Download uncompiled scripts from the downloads page. Open kray.ls and browse to line 493 - this is where presets are stored.
Re: render preset
It would be cool maybe in future after you type in Kray in the Cmds you can have a small add/Del button to store your own.
- matt gorner
Re: render preset
I've been thinking of adding this myself.vpii wrote:It would be cool maybe in future after you type in Kray in the Cmds you can have a small add/Del button to store your own.
Re: render preset
That would be very nice feature for sure.matt gorner wrote:I've been thinking of adding this myself.vpii wrote:It would be cool maybe in future after you type in Kray in the Cmds you can have a small add/Del button to store your own.
albertos2008
Re: render preset
ok I'm trying to modify presets...Download uncompiled scripts from the downloads page. Open kray.ls and browse to line 493 - this is where presets are stored.
how can I recompile scripts? (sorry about ignorance!)
thanks
- matt gorner
Re: render preset
You don't really need to, compiling them doesn't really speed them up in anyway (if it does, only a very small amount) maybe loading time if compression is used, not sure. It's just allows you to protect your source code mainly.albertos2008 wrote:ok I'm trying to modify presets...Download uncompiled scripts from the downloads page. Open kray.ls and browse to line 493 - this is where presets are stored.
thanks
But if you want to, look for the LSCompiler function in Layout (under 'Utilities' tab I think)
Don't worry about the 'Target' part, it will be changed to match the correct one for the script when loaded.
albertos2008
Re: render preset
uhm.. I've tried to understand how preset system works.. but for now is difficult for me..
I'm thinking that adding presets will be a must-have feature in the future releases..
very useful!
very useful!
