In this days I did some test on some old scene with new Kray.
The images below has been rendered respectively in 12 and 10 minutes on a quadcore q9650, 8 giga of ram. I used louminous poligons in the windows and physical sky.
The previous versions, somewhere on this forum, needed of about between 50 minutes and over than 1 hour (with a lighing system based on physical Sky and area Lights instead of lumi poly).
Waiting for your advises
Roberto
Old Scene, New Kray
Re: Old Scene, New Kray
very nice light!
i like this soft light. Very natural.
the time render is very very fast. Medium setting?
Settings are as follow:salvatore wrote:very nice light!
Footer Commands: recurse 20; importancegammamultiplier 1.4; lwo2unseenbyrays_affectsgi 0; (this is very important for the lighting and reflections, just look to Janusz Threads)
GI Resolution: AUTO
PHOTONS SETTINGS
Global Photons: 500.000
Use Autophotons
N: 500
Low 20%
High 80%
Steps 4
Precache Distance 50%
Precache Blur 100%
FG SETTINGS
Min/Max Rays 400/800
Prerender 100%
Passes 2
Sploth Distance 0.05
Sensitivity 0.05
FG Transparency/Refraction: Activated
Spatial Tolerance: 0.07
Angular Tolerance: 30°
Min/Max Distance 40% - 1000%
Blur Samples 2.0
SAMPLING SETTINGS
Preset High
Pixel Filter Box
Filter Radius 0.6
FSAA
Rotated Grid
QUALITY SETTINGS
Area Light Threshold 0.001, Min/Max recursion 2/6
Blurring Threshold 0.001, Min/Max Rays 1000/4000
Octree Detail: High
Roberto
thanks so much for the specific on your settings.
I will try my scene with your suggestions.
just a clarification: the illuminated panel is as big as the window? smallest? bigger? How far is the window?
thanks so much for your reply
It looks clean, but maybe a lack of contact shadows, and there is an overall pinkish color, maybe because of your floor?
for salvatore
the lumi polys are smaller than windows and are placed inside the room really closed to windows with a luminosity power between 400% and 600% (it depend from the size of windows, from how many windows you have and from the size of the room).
For Khan
You are right but it is somenthing I wanted and it depend from the color of lights. Later I will do a render more "cold" changing lights color.
thanks for your advice
Roberto
For Khan
Roberto
Nice work. You are improving. Keep on working on the materials.talats wrote:In this days I did some test on some old scene with new Kray.
Roberto
Thanks Jure.
Talking about materials, what would you do on them?
Roberto
Roberto
add more reflection...talats wrote:Thanks Jure.
Roberto
