filter radius bug
jdomingo_forum
filter radius bug
Post by jdomingo_forum »
hi
i dont know if this is a bug but it's bugging me, on the sampling tab, i choose "high" on the preset and filter radius changes to 0.5, now when i change that to 0.2 and close the kray panel and open to check, it went back to 0.5. so i thought maybe it is locked to whatever setting for "high" preset so then i choose custom preset and change filter radius to 0.2........again it went back to 0.5 after closing and open the kray panel. has anyone experience this? i dont know if changing 0.5 to 0.2 really make that much of a difference in the final render but knowing that it keep going back to default value it making me paranoid that all others settings i try to key in are going back to its default value. but so far the sampling tab filter radius is bugging me about this.
jdomingo_forum
Re: filter radius bug
i am guessing that 0.5 is the smallest value to put in filter radius, am i right to say this? is that why it keep going back to 0.5? because when i key in bigger than 0.5 and re open the panel, it does not go back to 0.5. so i guess it is not a bug after all. can anyone confirm this? thanks
Filter radius cannot be smaller than 0.5. This is why it resets to 0.5...
jdomingo_forum
alright cool, thanks jure,
mattgorner
Post by mattgorner »
Does the gadget in LScript have the range set? Might be worth adding that (to all gadgets that do in fact) if it hasn't. I'm sure you can set them up that way.
MattGorner wrote:Does the gadget in LScript have the range set? Might be worth adding that (to all gadgets that do in fact) if it hasn't. I'm sure you can set them up that way.
Yes it's possible. Will try to add them...
