Sumatra Plugin
Sumatra Plugin
hi boys, one question:
Sumatra Pro is compatible to kray? the price of plug in is accessible, so i want buy it but kray see the sumatra trees?
joreldraw
Re: Sumatra Plugin
Post by joreldraw »
Sumatra is only a plugin to clone object that include trees model.
I think that not problem with kray because you only clone mesh.
On the oficial website are Sumatra Lite for free. Try this first and check.
http://lwtoolbox.com/content/Sumatra_LITE.zip
Re: Sumatra Plugin
I'm trying the lite version, but with five trees the render time is over 2h in 640x480...as if kray don't see the clone but calculate all object
joreldraw
Re: Sumatra Plugin
Post by joreldraw »
I try this now and go fine. Whith 5 trees my render time are normal.
I set this to 100 trees and hard to render.
Read this: http://www.kraytracing.com/new/distribu ... ree+reduce
You can use this to speed up your render time
Re: Sumatra Plugin
in the afternoon i test on pc desktop, the notebook is old and with less ram :D
joreldraw
Re: Sumatra Plugin
Post by joreldraw »
Fast test
Clones: 100
Kray setup: Middle quality
Shader: Kray Surface option whith FG min: 25 max:100
Render time : 1m 56s
Re: Sumatra Plugin
nico wrote:I'm trying the lite version, but with five trees the render time is over 2h in 640x480...as if kray don't see the clone but calculate all object
I never used Sumatra but I believe it doesn't create Kray instances automaticaly. I think it only creates object clones.
joreldraw
Re: Sumatra Plugin
Post by joreldraw »
Yes Jure only create clone objects. I check this and work 100%.
You can use this whith Kray instance too.
Use the swap plugin here: http://www.kraytracing.com/forum/viewto ... f=2&t=1561 to convert clone objects to null
Re: Sumatra Plugin
joreldraw wrote:Yes Jure only create clone objects. I check this and work 100%.
Ah yes good tip!
