just some little fun project for my protfolio.
Rendered with Kray. Around 2.5 minutes per frame.
Animation (QT H.264) (I need to change the end so the cameramove comes to a smooth stop).
C&C welcome!
Cheers, Florian
Thanks. I did some post on it: some glow, vignetting and motionblur.theshape wrote:Yes, fantastic, very natural - congrats!! It's so clear, did You do any post on this ?
Hi,nico wrote:hi florian, very compliment for your work.![]()
it's very realistic
simply model but realistic surface.
the window glass is perfect one side surface or cube with airpolygons? can you post the parameter?
Hi Larry,Larry_g1s wrote:2.5 minutes per frame on that size resolution...you're killing me! I don't understand Kray well enough then to get renders down that well. Would you mind describing your settings a bit? Great job Florian.
There are two ways to use shared GI file. The simplest way is the one where you just choose "update" for shared GI mode. In this mode Kray will add missing samples to the shared GI file after each frame is completed and so will gradualy build GI solution along the lenght of the animation.Larry_g1s wrote:Thanks Florian. How did you cache the first. I don't understand KRAY's caching as with LW's. WIth LW's you set up the file then hit bake radiostiy, which then makes the file. But with Kray it doesn't work like that, so I'm a bit more confused on how to properly bake/cache the radiosty. Are you using BNR to network render Kray scenes on a farm?
