This is brilliant, the lighting is stunning, and the stucco and plants look fantastic.
However, some of the texturing isn't great. The brick texture in particular for me stands out as being poor and lets the whole image down. Also the front door has a single texture over the whole surface, which is incorrect. In reality it would be made up of a number of pieces whose textures would be slightly different. As it is it looks wrong.
Speaking as an architect, some of the modelling isn't right either. There is a recess that shouldn't be there where the bricks and stucco walls meet the ground.
The stucco/stone band should project over the bricks at the front creating a shadow under it. it looks flush at the moment, something looks a little strange here. In reality, this would be made of stone - or a concrete equivalent. The scalloped top of the tower would be the same material. I have never seen any craftsman able to create stucco like that. Also, the walls need a capping of some kind.
I don't mean to be too critical because the render is excellent. However I have seen your other work, and it seems to me like you really look for perfection
In these terms, it's good, it's very good, but it's not perfect.
We are getting into this difficult area where because the render is so good, anything that immediately looks wrong stands out. In some respects it's bad for architecture, because if you show a client something that looks this real, they will expect something that looks exactly the same when it is built. Images like this blur the boundary between reality and fantasy. It's really interesting, but at the same time quite dangerous, and we are getting into the Disney type architecture debate that we had on the forum a little while ago.
Some of these details can't be built exactly as shown, and if a contractor tries, they will fail. This may happen during construction, or a little while afterwards when the building is in use.
I guess what I am trying to say is that if these images are for sales or client presentation, the finished building just will not look the same as the image, and certainly not as good!
But, architectural issues aside, they are excellent renders. I can't wait to see the finished image(s)!
