Exterior
Exterior
Test render exterior: Sun+sunsky. Tonemapping Reinhard. 20 min.
I love the light balance between exterior /interior! and the vegetation looks great too!
jure wrote:I love the light balance between exterior /interior! and the vegetation looks great too!
Yes Reinhard is very close perception of eye. All renders have same setup (no change) For interior maybe scene need higher exposure but this is normaly in real world. Vegetation need transparency on leaf but this make too long rener. Now vegetation have around diffuse/translucency 50%/50% +specular.
I can render this under 10 min (very silimar render) but I like ideal radiation on walls. Water have Ani-reflection NODE for vertical reflections - maybe colour is no ideal (I used very basic setup ) but nice effect.
For exteriors we need:
1/ displacement in Kray
2/ grass/fur (basic) generator
3/ Reinhard toneampping
4/ multiple bounce light (glass problem under recurse 6 - too small bounce/recurse)
sepo
Post by sepo »
Very nice. I think these are benchmark exteriors. So your tonemapping was done in PS. Can you tell us more.
bigstick
Post by bigstick »
Bravo Johny - outstanding! Any chance of posting screenshots of your kray settings - please?!
geo_n
Post by geo_n »
very nice johny. this is the best so far. Can you tell us about the environment lighting and kray setup? I can't get noiseless render without removing contact shadow too much. Blurring sampling removes good shadow for my render. hmm...
larry_g1s
Post by larry_g1s »
Yessss! Very nice job. You're definitely on track. The 1st image is very very good. Looks like the blue material still needs some tweaking in it's texture. But other then that...top notch.
Man...just looked at it again...Beautiful work!
What is Reinhard?
Larry_g1s wrote:Yessss! Very nice job. You're definitely on track. The 1st image is very very good. Looks like the blue material still needs some tweaking in it's texture. But other then that...top notch.
What is Reinhard?
http://qtpfsgui.sourceforge.net/
larry_g1s
Post by larry_g1s »
Thanks Johny, I'll check it out. What is the connection to Reinhard? All I see is Qtpfsgui. :?:
Larry_g1s wrote:Thanks Johny, I'll check it out. What is the connection to Reinhard? All I see is Qtpfsgui. :?:
Just render to HDRi and use Reinhard02 or 05.
darickster
Post by darickster »
Johnny i can see the tool is either linux or mac, or is there a pc version?
ah, found it!
Just render to HDRi and use qtp
geo_n
Post by geo_n »
I use reinhard in vray for exterior, too. So I didn't know how to do it in kray. I'll check out that qtp program thanks.
Really need displacement in lw. The grass looks flat but when its far it looks good. I think your render is already photographic and only the sharpest eye can spot its cg. How did you make the walls glow without postprocess?
What does multiple bounce light mean? Doesn't kray do this anyway? And I mentioned in another thread that from recurse 16 to 8 I dont get significant render speed in kray. So is it important?
geo_n wrote: I use reinhard in vray for exterior, too. So I didn't know how to do it in kray. I'll check out that qtp program thanks.
16 recure is too big for exteriors. Try under 8 recurse.
For better speed You must know better Kray :D
geo_n
Post by geo_n »
yes yes johny. i'm learning. teach me more pls.:D hopefully lw still alive when i'm good with kray. LOL!
when i change rec from 16 to 8 in a 45min render it becomes 42min. maybe i'm not doing something right. but only 3min gain. in 4.5 hour render that's 4.2hour faster but still i'll go to sleep in that time. hehe
