DOF
albertos2008
DOF
Post by albertos2008 »
hi to everyone...
how can I activate deph of field?
all the LW settings are ok.. antialiasing, focal dist, f-stop
the openGL preview show it correctly..
but when I render on kray nothing happen
thanks in advance
Re: DOF
albertos2008 wrote:hi to everyone...
thanks in advance
Best for me is:
1/Active Real Lens Camera in LW and choice some camera (Canon A10 Lens STANDARD, Irradiance fallof 1.0)
2/ Active Depth of Field in LW.
3/try use: Lens F-Stop around 1.2-1.8, Focal Distance You see from Top View in LW.
4/under Kray Turn ON FSAA G6 Mitchell (minimum setup)
This setup are in this renders:
http://www.kraytracing.com/forum/viewtopic.php?t=1245
http://www.kraytracing.com/forum/viewtopic.php?t=1239
For fast prev You can use low FG ( 200/0) and FSAA G3.
Best DoF You can see when You use G10 FSAA
For very fast DoF You can use DoF Pro under PS (You must render Z-buffer under Kray), but better is when You use oryginal DoF from LW (better quality/realistic)
Macdoggie_forum
Post by Macdoggie_forum »
Very Impressive!!! and thank you immesnsely for sharing your scene!!!
Cheers mate
albertos2008
yes... thanks johny
I've understand so much with very few post!
