animation - 2pass
sat
animation - 2pass
Post by sat »
I have a scene where only the camera moves and some animated people (clip maps). When rendering the scene I have noticed, that the people do not move. Their walking animation works but the planes, they are mapped on stay in place. Does anybody know why this happens. Is it because I have rendered it in 2 passes? (first pass every 10th frame)
When I render a single frame of the animation the people are moved correctly.
Thanks in advance.
Post by silverlw »
it's because Kray freezes all objects static in place when you use krays "Shared gi for all frames". Next update will have this limitation removed so even if the actual GI aint updated objects should be able to move around anyways.
sat
Post by sat »
Thanks Silverlw.
