Diffuse model Raytrace
sat
Post by sat »
Hello,
does it make sense to render glass (for example windows) with the diffuse model raytrace instead of photon mapping? Will it speed up the render process? Thanks in advance.
acidarrow
Post by acidarrow »
I'm not sure, but sounds interesting enough to do some tests on it, will report the results once I'm done (may take a while though)
Captain Obvious
Post by Captain Obvious »
No. Glass shouldn't have any diffuse anyway, and GI is only calculated for surfaces that have nonzero diffuse and color.
sat
Post by sat »
Thanks.
keeejreeej
Post by keeejreeej »
So, should glass be set to specific diffuse model (raytrace) or not?
And what about "Control FG Rays"?
Captain Obvious
Unless you have diffuse on your glass (which you shouldn't!), there's no need to do anything.
