Hi kray users,
We have a problem with a nodal setup we use. We want to plug the translucency node into diffuse shading. This is for sky dome construction and translucent surfaces like leafs and canvas. When we render it with lightwave it works, but kray doesnt take it.
We can plug it into the translucency receiver but that doesnt look nice.
Is there a different approach for this in kray?
Grtz,
Fabian
Translucency nodal question
Re: Translucency nodal question
I do not think so it will work in Kray.
If you want use translucency then only one way is standard set up. Also for leafs Side Surface Translucency is good solution is (soon I will update new surfaces in Nodes Topic).
