Problem with Kray update...
I was using the 1.612 demo and then bought Kray 1.70B. I removed the demo from lightwave, replaced the demo .ls and .p with the new ones and restarted lightwave. I then added the new plugins. The new interface is there but when I go to render the render window still says 1.612 and has the watermark at the bottom...
remove all krayplgins from lw and doublecheck they are not there in the pluginlist. You must have 1.612 still on disk otherwise you would start it and see it
Keep the lw_about.tga image though since kray 1.7 will also look for it.
You can find that lw_about image here
http://www.kraytracing.com/forum/viewtopic.php?t=417
