I've been using the demo (1.612) extensively recently because I'm considering buying Kray for my business. Unfortunately, I'm becoming increasingly worried by the Unexpected Exception error that Kray often throws when a scene becomes complex (over about 800,000 polys). The error usually appears after the "Octree" message early on.
I know the way around this is to remove objects from the scene until you identify the one that is causing the trouble. However, I have often found that there is nothing actually wrong with the object itself - and it will usually render fine on its own. The problem appears to stem from the complexity of the scene itself, or some interaction between that and the offending object.
Since I'm just evaluating the software, this is merely frustrating. However, were I using it for work it would be a disaster as I simply wouldn't have the time to mess around trying to find ways around this error.
I'm just pointing up a concern here, not issuing criticism, as I think in general Kray is wonderful. But it really must be made more robust with complex scenes.
Thanks for reading!
Phil
Unexpected Exception Woes
- phile_forum
