Kray 2.51 released
Kray 2.51 released
We just released small update that addresses a few crash reports we've been getting. You can download it in our download area.
- djwaterman
Re: Kray 2.51 released
I just dropped all the Kray plugin files into the Kray plugins folder to replace them. When I opened Lightwave, Kray was still called Kray 2.5, should it say Kray 2.51?
Should be 2.51...be sure You do not have another version on hard drive (Lightwave scan for plugins and maybe You have Kray.p from another source)djwaterman wrote:I just dropped all the Kray plugin files into the Kray plugins folder to replace them. When I opened Lightwave, Kray was still called Kray 2.5, should it say Kray 2.51?
- djwaterman
Would I have been better off just cleaning out the old plugins and reinstalling Kray?
- djwaterman
What's the procedure to uninstall Kray completely? No matter what I do I just get the 2.5 version, it doesn't ask for my license and just opens up. I removed all the plugins and config, replaced them and went through the installation procedure but it just loaded up working and didn't ask for the license, and still says 2.5.
try rendering something, it will show 2.51 on render preview panel. yup it shows 2.5 on the UI but it doesnt crash anymore with using spherical light or ies.djwaterman wrote:What's the procedure to uninstall Kray completely? No matter what I do I just get the 2.5 version, it doesn't ask for my license and just opens up. I removed all the plugins and config, replaced them and went through the installation procedure but it just loaded up working and didn't ask for the license, and still says 2.5.
- djwaterman
Thanks, it says 2.51 in the render panel.
It should display 2.5 in Kray master plugin panel (nothing changed there from 2.5) but in render window it should say 2.51.jdomingo wrote:try rendering something, it will show 2.51 on render preview panel. yup it shows 2.5 on the UI but it doesnt crash anymore with using spherical light or ies.djwaterman wrote:What's the procedure to uninstall Kray completely? No matter what I do I just get the 2.5 version, it doesn't ask for my license and just opens up. I removed all the plugins and config, replaced them and went through the installation procedure but it just loaded up working and didn't ask for the license, and still says 2.5.
