PhySky/ Photonmap/ Lightportals
Jim M
Post by Jim M »
Hi All,
If you use photonmap method, I understand background illumination like a gradient or Sunsky won't work (probably as there is no way to point to them as items for Lightportals). My question is, how does Physical Sky interact with Lightportals? Are there methods to make a connection between them? I hope the question makes sense.
Many thanks,
Jim
Re: PhySky/ Photonmap/ Lightportals
Jim M wrote:Hi All,
Many thanks,
Jim
Physical Sky doesn`t works with LightPortals yet. Only way to use it is use new sunsky as lumi sphere and then You can choice in shader source of photons for portals. Also new Sunsky has nice control for position of Sun...so this will be easy.
http://dpont.pagesperso-orange.fr/plugins/Sunsky.html
Jim M
Post by Jim M »
Thankyou for the quick response Janusz.
This might be a good idea.... if render method is set to Photonmap, the PhysSky plugin is greyed out. Just so new users don't go down dead end roads. Just a thought.
J
Jim M
Post by Jim M »
Do you mean use SK Sky Light and SK Sun Light in concert?
Jim M wrote:Do you mean use SK Sky Light and SK Sun Light in concert?
Yes. I use only this, interior/exterior.
medzo
Post by medzo »
what would be the benefit of using lightportals? aren't lumi polygons enough?
medzo wrote:what would be the benefit of using lightportals? aren't lumi polygons enough?
Portals are just tool for correct photons which have all the time problem with small windows (and sometimes curtains) for example when they travel from outside to inside room. Portals only reduce problems with splotches or light leaks...they are not magic tool for good render.
medzo
Post by medzo »
so, for interior renders we should use both lumi and lightportals?
medzo wrote:so, for interior renders we should use both lumi and lightportals?
I think, Lightportals are quite complicated so better Area Lights and Lumi Poly.
Jim M
Post by Jim M »
Thanks Janusz
