jnom how to save the cfg kray and by what name?jnom wrote:Regarding the config, if you're using the default config then there's a folder called Main Config>Config somewhere depends on your amleto installation. Kray key has to be there.
Amleto network render controller
Re: Amleto network render controller
Maybe I am missing something obvious but I also have similar difficulties with kray and amleto.
Does the licencetool generates somewhere a licence file when I paste the serial code that needs to be in the main config folder?
sotto3d.com
Has anybody passed the problem with amleto and kray licence file?
sotto3d.com
I am also getting the license key error in Amleto... is there no solution to this?
Guys having trouble with amleto might want to try this
http://forums.newtek.com/showthread.php ... ost1379895
