simple interior
simple interior
Post by salvatore »
a new simple interior
all advire are welcome
tnks
simple interior
simple interior
Re: simple interior
imho
:D good:
- light/contrast
- very good surfaces
:evil: Crap:
- GI over cabinets in corners
- reflection blur
- AA
Render need just a bit dot the I. Also ceiling is too washed (maybe too strong desaturate shader from wood?...should be more warm, not that clinic white)
Re: simple interior
Post by salvatore »
Janusz Biela wrote:imho
:D good:
- light/contrast
:evil: Crap:
- reflection blur
- AA
thanks Janusz
Your suggestions are precious to me
Yes true! wood desaturate was 100%
Now i setting 90% (better or still less?)
in the cabinet i will put a lumy panel with less luminosity than lumy in windows
The bad is very simply but the evermotin models are too agly to me.
I must model a good bed :oops:
For reflaction blur i used 500-2000 1% with importancegammamultiplier 1.0
You advice a better setting?
Thanks for all
Re: simple interior
salvatore wrote:
thanks Janusz
If you will setup good tonemaping and lights you don`t need desaturate shader (sometimes it is necessary use desaturate for strong vivid colours) I think 50% is maximum ...after that surface start look artificially.
Thanks for all
Last time I give up this function (is too much "flow", in one scenes blur looks good in another bad with the same setup...but this is not bug, I think, problem is with quantity of reflection in scenes, more quantity of reflection - need more min/max for this parametr...but I am not sure of that.
Try importancegammamultiplier 1.4 and 5000/20000 or old engine with min/max 200/1000 or more.
