I usually set the falloff distance to the distance of light from object - so that the circle of falloff distance just touchec the object. Then you only need to have light at about 100-200%.Josamoto wrote:
I dunno if I'm setting my light up the right way. I mean I could also change the falloff to say 100m and adjust the brightness accordingly, but I'm not entirely sure which way is right.
What is your GI resolution? Are you using auto? If not do so... Your cells seem too big. You can make them smaller with lowering "precache distance" also but usually auto GI resoulution takes care of that.
Also turn to precomputed filtered and check if irradiance is smooth...
