Sorry if this has been explained here before. Is there a way to add to header or trailer commands so there are there always?
Regards
commands
- khan973_forum
Re: commands
You mean in the list?
That's what I'd like to do.
- khan973_forum
Re: commands
Re: commands
yes, add to the list so it is always there.
Re: commands
You'll need to modify the uncompiled Kray.ls Lscript (the HTML link to those is in the 2.0 RC5 install ZIP file)
Open Kray.ls in a text editor and look for this bit of code:
Then simply find the command you want from the online documentation, and add it, e.g:
"finishclose",
Make sure you add the comma at the end if you place your newly added command at the beginning or in the middle of the others. If you place it at the end of the list you don't need to add one, but make sure you don't remove the closing @; or you'll get an error.
Also, make sure you leave the "Add ...", at the beginning.
Cheers
Matt
Code: Select all
//header/tailer commands
header_list=@"Add ...",
"previewsize 1280,800",
"debug -1",
"logfile 'kray_log.txt'",
"renderinfo '%kray% %ver% %time% | %width% x %height%'",
"showphstats",
"octstats",
"renderinfosize 0.5,10",
"usemultipass 1"@;
tailer_list=@"Add ...",
"showphotons 0",
"irradianceblurgamma 0.3",
"lwo2airpolys 1,0",
"octree <depth>,<object per octree leaf>",
"postprocess desaturate, 0.1",
"postprocess gamma,1.4",
"postprocess gblur,15,0.4",
"postprocess mult,(3,3,3)",
"postprocess ca,0.1,1,2,100",
"postprocess erode,5;",
"recurse 100",
"surface_flags 0+1+2",
"cam_singleside 1"@;
"finishclose",
Cheers
Matt
- khan973_forum
Re: commands
Thanks Matt, it will be very handy to add the "get Johnny's super render settings" command
