surface baking
surface baking
I haven't done any surface baking in kray. Does it work with surface baking camera or surface baking shader? which ao works best with kray? thanks.
Re: surface baking
For surface baking I suggest you use Kray texture baker. You can select this mode in the General tab under Camera dropdown:
http://www.kraytracing.com/wiki/GUI_-_G ... tab#Camera
About occlusion - i haven't tried many but for me Grit node works the best.
Re: surface baking
Alrighty I will try grit node. Thanks!
Re: surface baking
jure wrote: About occlusion - i haven't tried many but for me Grit node works the best.
yes this GREAT tool (very fast) I thing abount this to use for all surfaces with poor GI....
btw. Need mixer in node with normal texture for reduce effect.
