skylight.p plugin
skylight.p plugin
I have read through one of the tutorials which mentioned the skylight.p plugin. I can not seem to load it in to lightwave 9.3 is there an alternative route?
- phile_forum
It's part of Denis Pontonnier's Renderman collection.
They're all free and downloadable from here:
http://pagesperso-orange.fr/dpont/plugins/Textures.htm
Phil
Phil
- phile_forum
Not recognised? Can you give more details? Works fine on 9.3 here.
Have you tried to load the plugin (Edit->Plugins->Add plugins), or have you just put it in the plugin folder? It might need to be specifically loaded the first time. After that, LW should be able to find it for itself.
sunsky plugin
I have loaded the sunsky plugin, play around with all the settings, any pointers?
