install kray3
jean-claude
install kray3
Post by jean-claude » Sat May 04, 2019 2:39 pm
Bonjour
Y a t il quelque un qui parle Français et qui pourrait prendre la main sur mon ordinateur pour me faire l installation de Kray 3 correctement?
Je suis en Suisse. J ai un Mac.
J ai essayé de le faire mais sans succès. Ca plante quand je test.
Je fais surement une erreur.
Merci à la communauté Kray ;-)
JCé
ZodiaQ
Re: install kray3
Post by ZodiaQ » Mon May 06, 2019 11:59 am
Please pay attaention, Kray V3 is not yet (production) ready for LW 2018/19.
Only recently a version has been released for LW 2018/19 but it is still a beta stage and likely to crash.
jean-claude
Re: install kray3
Post by jean-claude » Tue May 07, 2019 7:15 am
Merci pour la réponse, mais je l ai installé sur la version 2015 ;-(
ZodiaQ
Re: install kray3
Post by ZodiaQ » Tue May 07, 2019 4:56 pm
make sure you only copy the files corresponding to your system.
Create folder for k3 plugins and copy common and MacOs in there except kray3_lw2018.plugin as you said you have LW2015. (kray3_lw11_6.plugin works for 2015 as well)
Start LW and add all files from plugin folder. You should be ready to go
Accom
Re: install kray3
Post by Accom » Wed Jun 05, 2019 7:21 pm
Hello everyone!
I'm new here, just downloaded the trial. I'm also on a mac, OSX 10.14.5, LW 2018.0.7
I followed the installation guide. After copying the .lsc scripts and Kray.plugin to appropriate locations, adding them to LW and restarting the app, I found no way to access the Kray GUI. After browsing arround (I have never used any plugins - out-of-the-box Lightwave allways seemed just fine for my modest requirements) I managed to find the Master Plugins button under Utilities, adding Kray and accesing the GUI. But after hitting render frame, I get this error message: "Plug-in KrayFrame failed to start".
Googled it and found nothing... Should I start reading the internet from the begining? :)
Thanx in advance!
Re: install kray3
Post by Janusz Biela » Wed Jun 05, 2019 7:42 pm
Accom wrote:Hello everyone!
Thanx in advance!
Hi
Please do not use K3 for LW18-19 is not yet fully operated.
but if you want use for testing here is short info:
1. Create folder called K3 (or whatever you want)
2. Copy all files from Common folder (K3 package)
3. Copy kray3_rsrc.ka (K3 package) to K3 folder.
But I am not sure is G. updated plugin for new Lightwave that's why you get error. It can be you try run plugin for LW15 in LW18....
The reason of that is maybe plugin for OSX is not ready yet.
Can you check LW15 ? I do not heave here OSX to verify this.
Accom
Re: install kray3
Post by Accom » Wed Jun 05, 2019 11:08 pm
Thank you! It works in 11.6.3. with no problems. I'm gonna thoroughly test it out. :)
----- edit -----
But demo is 2.6.1, not 3! I thought it would be 3.something... :(
Re: install kray3
Post by Janusz Biela » Wed Jun 05, 2019 11:14 pm
Accom wrote:Thank you! It works in 11.6.3. with no problems. I'm gonna thoroughly test it out. :)
----- edit -----
Yes probably he updated only LW11 for OSX.
Demo K3 still unavailable.
Accom
Re: install kray3
Post by Accom » Wed Jun 05, 2019 11:23 pm
I must say, I'm impressed... speed is unbeliveable!
Is the timeline for K3 known allready? When can we expect it? Or maybe I just might grab some second hand Wintel Workstation for this.... :D
