I'm diving into sort of physically accurate nodes and qmc, and am ready te learn, so all suggestions are welcome!
Here's my first test render and setup info (render settings and computer info). Raw, no post.
A have a couple of quick questions:
1) What do you think of the render time? As the info below says: 22 minutes on an i7 at 4 Ghz, with 16 GB ram. Windows 10. Full HD resolution. Giving the simple nature I would think it should be able to go lower, but I haven't had any success there.
2) Noise: I'm using 100-800 samples. Going higher seems to be overkill. Is the current level acceptable to go into post (and denoise in Photoshop or other), or should I be able to get it lower in the raw image.
3) Any other general comments to help me progress?
Cheers!
Thomas
