Bugatti v02
Bugatti v02
Here test in LW2015 + new Kray update...but I got problems: it was so many changes in new Lightwave so I got also problems with this scene , crash from LW (without Kray) and strange behaviour during render in Kray. I think the mess in lws format file maked it so I build scene from zero (nothing was imported, no Load Items from scene) Kray setting also setup from zero...and now seems be ok :wink:
I am not sure it is problem with lws and I we will watch with G. this strange behaviour.
Render in Path Tracing 12 min. Post as always After Effects.
Alexis
Re: Bugatti v02
Post by Alexis »
I have same problem. I delete all Kray plugin in "Master Plugins", close LW, hub, and restart, reload Kray and it's ok for me.
Re: Bugatti v02
Alexis wrote:I have same problem. I delete all Kray plugin in "Master Plugins", close LW, hub, and restart, reload Kray and it's ok for me.
I suspect there in LWS are some procedures which are not wiped and of course for LW2015+Native Render is no problem but seems problem for new Kray. It was that story in past tense when Newtek make "big" update and Kray had problems even when plugin update was correct.
This Buggati scene had problem also in Lightwave without Kray! The scene after loading ate my 64 Giga RAM memory up to ZERO after 10 min doing nothing!...I think Newtek must think about update for LW2015 seriously (I think it is or it will be soon v02)
Thanks for info!
Re: Bugatti v02
new kray work fine For me . i have lw 2015.1 i think.
good stuf janusz ^^
