Can I have request? I am trying to do realistic tree with xFrog model and model is very good but I seem to have rpoblems to get texturing right... after 2 hours of playing still is nowhere close to realism...
Can someone upload a good scene with a tree to study? Is that technical support question? ...ish
BTW Thx for all previous answers and suggestions.
tree model to reverse engineer
Cheers
Tomek
GarageFarm.NET
We are the cheapest render farm! 260 nodes and still growing!
Skype: garage.farm
Tomek
GarageFarm.NET
Skype: garage.farm
Re: tree moder to reverse engineer
Just keep basic setup:Soth3d wrote:Hi,
diffuse for leafs: ~70%
reflection 3-5%
translucency 30-60%
You can use specular 20/45 (fake reflection from Sun)
For translucency better is use map (more realistic)
We test now new function in Kray: double translucency, I hope this will raise quality for plants.
btw: I playing 1.5 Year with plants for better realistic
That is pretty much what I did What is this blue thing I wonder... any ideas? There is something wrong with transparency... well I will work on it tonight... I played with it and looks like no matter what option I am choosing I got this nasty semi transparent polygons. I cannot use clip maps with instancing, can I?Johny_quick wrote:Just keep basic setup:
reflection 3-5%
translucency 30-60%
http://soth3d.com/shared/v001.jpg
help! ;(
Cheers
Tomek
GarageFarm.NET
Skype: garage.farm
Tomek
GarageFarm.NET
Skype: garage.farm
He he.Soth3d wrote:That is pretty much what I did What is this blue thing I wonder... any ideas? There is something wrong with transparency... well I will work on it tonight... I played with it and looks like no matter what option I am choosing I got this nasty semi transparent polygons. I cannot use clip maps with instancing, can I?Johny_quick wrote:Just keep basic setup:
reflection 3-5%
translucency 30-60%
help! ;(
Just use clip map on oryginal object (cloned object will get clip map setup automatically)
You can use also transparent map (as You used) but You have to use clip map as ALPHA)
I suggest Clip.
Re: tree model to reverse engineer
cheers!
Now, looks much better (but I had to fight with UV maps - there was only one, so clip map (as being per object not per surface) did not work very well.)
Now I am trying to do something similar to Vue (just much cheaper and faster), wish me luck!
PS Can I have NoRender Flag on KRay object? LW visibility controls seem to be not working...
Cheers
Tomek
GarageFarm.NET
Skype: garage.farm
Tomek
GarageFarm.NET
Skype: garage.farm
Yes it works for regular objects - not for instances. If you want to disable instances then just uncheck "enable plugin" inside kray instances panel.Soth3d wrote:cheers!
I think I did not save the scene before rendering.jure wrote:Yes it works for regular objects - not for instances. If you want to disable instances then just uncheck "enable plugin" inside kray instances panel.Soth3d wrote:cheers!
Cheers
Tomek
GarageFarm.NET
Skype: garage.farm
Tomek
GarageFarm.NET
Skype: garage.farm
