K3.05 official release + Demo K3 for LW15 and LW18+
Official release:
Code: Select all
History:
3.05 3-01-2020
- new improved light portals added to core (old portal system removed, SDK+LW GUI soon)
- memory usage optimizations (geometric primitives,geometry groups,photons)
- surface level clip maps added (lower memory consumtion for clip mapped geometry than shape level clip maps)
- shader sampling model refactored
- small raytracing optimizations
- improved texture filtering
- clip camera added to LW interface
- experimental 3d texture, instance and bitmap+uv displace modes added to core (SDK+LW GUI soon)
- bugs fixed:
	BSDF specular slow/freeze
	LW2019 Node Image crash K3
	polygons Instance error
	Unseen by Camera couse visible edges
	Unseen by radiosity not working
	Z-buffer with glass
	Wire Error
	refraction block photons
	Power Shader not working
	Instant crash
	Crash after finishing render
	Crash when press button
	Clip Map Crash
	Crash
	Crash when Instances
	+ more small fixes
ZodiaQ
Re: K3.05 official release + Demo K3 for LW15 and LW18+
Post by ZodiaQ »
Cool, installed and running.
BTW is bugtracker page offline? (404)
ZodiaQ wrote:
Mon Jan 06, 2020 3:52 pm
G. update PHP on bug tracker. Soon we back on line with tracker.
LW19 works fine. There is bug in Lightwave with specular so G. had to write bridge over that and thats why we have noisy some shaders. This will be fix soon + Spherical/IES lights also added. We are very close to have full LW19 support!
ZodiaQ
Post by ZodiaQ »
Some of my surfaces act strange under 3.05. Have to revert to 3.04 for now.
Surfaces are clipmapped. Bug?? LW11.6.3
re-upload new version
Code: Select all
History:
3.01 09-01-2020
- fixed transparency issue when refraction apply
- fixed double surface polygon issue
ZodiaQ
Post by ZodiaQ »
Still problem with 3.051.
Shadows are not rendered clip mapped :
3.051 vs 3.04
ZodiaQ
Post by ZodiaQ »
Found the problem. When object is set to 'unseen by camera' shadows don't respect object clip mapping shape.
When 'unseen by camera' is unchecked render is ok.
ZodiaQ
Post by ZodiaQ »
It seems that both 'unseen by camera' AND 'unseen by rays' need to be unchecked for correct shadows.
This is a problem for my workflow as the trees i use for casting shadows should not be visible in reflections.
This concern LW11 (it doesn`t contain surface Clip Map) I put it on bug tracker.
ZodiaQ
Post by ZodiaQ »
Janusz Biela wrote:
Wed Jan 15, 2020 9:52 am
This not only affects LW11 but 2015/18/19 as well! Shadows are not respecting clip map no matter if object or surface clip mapping is used.
This is problem with flags in SDK. G must fix it.
