K 3.001
K 3.001
Post by Janusz Biela » Wed Jan 09, 2019 9:43 am
We testing now new tone map: tanh
Here are some information about it (not exactly but similar):
http://www.robots.ox.ac.uk/~dre/docs/el ... tj_4yp.pdf
Also we have new scene loader (LW - K3) which is incredible fast (20-40 times faster!). Heavy scenes which took 3-4 min to start now needs seconds....
I have not yet ready images with new tone map but I will upload it soon.
Re: K 3.001
Post by Janusz Biela » Wed Jan 09, 2019 9:08 pm
I got more info from G. about new tone mapper:
Here is formula:
https://www.desmos.com/calculator/pqps9qmusu
I marked two red dots too see image brightness scale - this what we see.
0,0 means dark (GUI Tanh 0)
1,1 means white (GUI Tanh 1)
Playing with parameter i0 you increase dark regions (negative value like -1, -2, etc)
Playing with parameter i1 you reduce over bright area (value 2,2, etc)
Probably we will have it in GUI interface as graph for tone map.
Re: K 3.001
Post by Janusz Biela » Thu Jan 10, 2019 12:47 am
We have also real time tone map!
Under K3 window (LW GUI window image) render is what I got directly. Over in K3 window is after my tweaking tone map by changes values in real time 8)
Re: K 3.001
Post by Janusz Biela » Thu Jan 10, 2019 10:11 am
I have better version of curve explanation:
https://www.desmos.com/calculator/whrywdjh7t
cruisermori
Re: K 3.001
Post by cruisermori » Thu Jan 10, 2019 11:24 am
Can you save an image from K3 window after TM tweaking?
Re: K 3.001
Post by Janusz Biela » Thu Jan 10, 2019 12:09 pm
cruisermori wrote:Can you save an image from K3 window after TM tweaking?
Yes...from command line right now.
But I send to G. priority request to add save button in next update (soon official release K3.01 - we test now K3.001).
Re: K 3.001
Post by Janusz Biela » Thu Jan 10, 2019 1:38 pm
...actually I got update right now with save image after real time tone map 8)
cruisermori
Re: K 3.001
Post by cruisermori » Thu Jan 10, 2019 4:24 pm
Wow. That's great and super fast.
Re: K 3.001
Post by Janusz Biela » Thu Jan 10, 2019 9:52 pm
soon update
Old tone map:
New tone map:
Probably we can better but tool is new so I am green with this - need researching and testing.
Re: K 3.001
Post by Janusz Biela » Mon Jan 14, 2019 8:33 pm
So I have updated Kray to version K3.01 already - just checking is ready for release 8)
