Altus rendering denoising system
A place to hang out and talk about everything else...
promity
Post by promity » Fri Jul 14, 2017 9:19 am
Altus rendering denoising system released
Oct 29, 2015 by CGP Staff 0 |
InnoBright has released Altus 1.0, a multi-platform Monte Carlo render denoising system that promises to significantly reduce the rendering time required to produce quality images (from 50% to 90% reduction of original rendering time, according to the company). Altus works with renderers that use Monte Carlo methods and currently supports Arnold, V-Ray, Redshift3D, Corona, etc. It’s available as a standalone application and as an integrated plugin for specific 3D software.
Also of note, InnoBright is working together with other researchers in the field to achieve real-time filtering of the noise of an image. Read the FAQ and find out more on InnoBright.
http://cgpress.org/archives/altus-rende ... eased.html
https://www.innobright.com
Alexis
Re: Altus rendering denoising system
Post by Alexis » Sat Jul 15, 2017 10:58 am
Yes, need exr file for always buffer export..
I have not managed to make it work with render Kray. If you have tips?
Post by Janusz Biela » Sat Jul 15, 2017 11:59 am
Exr you have in K3
