Kray Menu Access Scripts
mattgorner
Post by mattgorner »
Hi Guys
I wrote some scripts to aid calling ALL but the surface plugins from the main LightWave UI. Also created a menu branch for you to import. Saves having to create one from scratch.
Hope you like!
Cheers
Matt
P.S. I think I might make these multi-select aware, so you can add the plugins to many selected items.
P.P.S. Let me know if you come across any bugs!
Kray_Menu_Access_Scripts_v1.1.zip
v1.1 Update (See my post below)
(9.79 KiB) Downloaded 457 times
The imported menu branch
mattgorner
Re: Kray Menu Access Scripts
DOH!
Like an idiot I missed one of them out!
If you downloaded, re-download! Sorry about that!
mattgorner
For some reason, the Instances and Photon Multiplier scripts when first applying Kray Plugins to the selected object/light won't bring up the UI. If that happens to you, just click the button again and it will invoke the UI (it won't add another plugin, it checks for that).
Not sure why those two scripts do that, the others seem fine.
I can`t open it...wrong archive?
geo_n
Post by geo_n »
great. thanks for these. will try em out.
btw is it hard to make them "multiaware" and apply an instance to different nulls at the same time. I requested this for hdinstance and kray instancing.
There's more control with instance nulls than points, particles.
khan973_forum
Post by khan973_forum »
Yes, Somehow, but as you can edit particles and move them as you want, you can still get control. But i don't know if you can get realtime feed back then.
khan973_forum
Thanks Matt, always good to see how you contribute to everything you get involved in
bigstick
Post by bigstick »
Well said khan! It's great to see people actually doing things and making positive contributions instead of asking questions and hoping someone else can help.
Of course there's nothing wrong with this by any means, but actually going to the trouble to make things which are useful is way better. I wish I could do more of this - thanks Matt!
mattgorner
UPDATE: Kray Menu Access Scripts v1.1
v1.1 UPDATE:
DOH DOH DOH DOH DOH! :D
Okay, I realised what I was doing wrong. When first adding any of the plugins, I wasn't rebuilding the array that contains the list of plugins when checking that to see if the plugin was already added (to bring up the UI) and because the script was originally checking so quickly after adding, it sometimes wasn't "there" because of this.
I looked at the KrayOptions.ls which made me go duuuuur, of course!
Sorry about that. Here's an update, you can just drop these over the top of the others if you downloaded them. These will work properly now and bring up the plugin UI on first add.
Cheers
Matt
P.S. Will look into multi-add for the instances / photonmultiplier plugins (which means I should also write a strip instances / photonmultiplier script too I suppose!)
(9.79 KiB) Downloaded 433 times
mattgorner
Johny_quick wrote:I can`t open it...wrong archive?
Should be okay now (see above post) first ZIP was using newer ZIP compression and not 'Legacy' mode.
mattgorner
BTW: If anyone wants to see what these do, I'm using them in this video:
http://www.kraytracing.com/forum/viewto ... f=4&t=1744
joreldraw
Post by joreldraw »
Nice MAtt
Thanks for your aportation to this world.
This is i love that Vray and Max world don´t have!
