physky2
physky2
Postby Keraressi Abdelkarim » Tue Jun 04, 2019 1:05 pm
hey . i think we need to separate sun from physky2. to gave more option :
because now. if u want to get bright day and with orange yellowish sun we cant. becuause sun locked with physky rotation ex... it can do it only with lw light but we will miss that softness effect ex.. and quality ofcourse from physky2 sun.
i said this because Corona has same things as kray2 but sun is sepratly not folowing sky. wich is great and offere more option to user . thank you .
Re: physky2
Postby Janusz Biela » Tue Jun 04, 2019 1:32 pm
You have saturation values for both light sources (Physky and Sun). Soft shadow has physical behaviour with value 1.0. If you wan more soft shadow you must override this by higher number.
Usually I suggest use 50% de saturation for Sun and 75% for Physky.
Try use +75% for Physky (more grayish) and -50% for sun (very warm)
Re: physky2
Postby Keraressi Abdelkarim » Sun Jun 09, 2019 9:42 pm
Janusz Biela wrote:You have saturation values for both light sources (Physky and Sun). Soft shadow has physical behaviour with value 1.0. If you wan more soft shadow you must override this by higher number.
hello januysz negative value it not working nicely as when u choose color . it will give in somesituation weird color effect.
Re: physky2
Postby Janusz Biela » Mon Jun 10, 2019 8:54 am
Try:
+80% Physky
-50% Sun
Return to “technical information”
Who is online
