K3.03 official release
Post by Janusz Biela » Fri Apr 26, 2019 11:47 am
Log:
Code: Select all
3.03 26-04-2019
- displacement (beta)
- LightWave shader model (2018/2019) support improvements (beta)
- bug fixes:
	Hot photons
	GI error when Displacement
	red surface
I asked G. when will be update for LW2019 because I do not see plugin in official update.
Re: K3.03 official release
Post by Janusz Biela » Fri Apr 26, 2019 1:32 pm
Also LW2018/2019 updated right now.
giacob
Post by giacob » Fri Apr 26, 2019 3:28 pm
dOESNT.T WORK HERE ON 2019.03
Post by Janusz Biela » Fri Apr 26, 2019 4:37 pm
It works just you must be careful with surface settings and better rebuild scene. Now we start fixing bugs in LW2019 (IES still not supported, Spherical Ligh also) and others small.
I checked all LW2019 Shaders and they works perfect.
promity
Post by promity » Fri Apr 26, 2019 4:40 pm
Working in lw 2019.0.3 but with strange artefacts.
Default materials, K3
Default materials, LW
giacob
Post by giacob » Fri Apr 26, 2019 4:41 pm
maybe something went wrong with installation but it says kray failed to start
Post by Janusz Biela » Fri Apr 26, 2019 5:48 pm
I just check how it works....LW2019 is new for me also these materials.
There are some bugs but important is all shaders works!
G. made fantastic job!
Now we need a bit time to catch bugs and polish plugin for LW2019 :D
No worry is just first run 8) Important is I can run normal scenes - and starting post bugs!
From now LW2019 is priority for K3 (Lightwave department of course)
Post by Janusz Biela » Fri Apr 26, 2019 5:50 pm
giacob wrote:maybe something went wrong with installation but it says kray failed to start
Ignore failed plugin info when you load scenes from older Lightwave. This we do later.
cruisermori
Post by cruisermori » Fri Apr 26, 2019 6:10 pm
Does displacement work in LW 2019?
Post by Janusz Biela » Fri Apr 26, 2019 6:18 pm
cruisermori wrote:Does displacement work in LW 2019?
Did not check yet.
btw
Time to learn shaders :)
https://docs.lightwave3d.com/display/LW2018/Delta
ZodiaQ
Post by ZodiaQ » Fri Apr 26, 2019 11:21 pm
Cool!
Released on a Friday grrrr. Now I have to wait till Monday to be able to really play with this lol. :D
Post by Janusz Biela » Sat Apr 27, 2019 1:10 pm
Important is now that we can run engine. I posted already bugs so we forward situation. I am also excited because I want test Unreal Engine in the same time (exporter from new LW) and also new LW shader system. Also I like very much LW2019 GUI, new features and stability.
ZodiaQ
Post by ZodiaQ » Mon Apr 29, 2019 1:42 pm
How does displacement work in K3.03 for LW11?
Post by Janusz Biela » Mon Apr 29, 2019 8:36 pm
Add shader on surface: Kray3Displacement
Distance is the height of bump
Max march is how many steps engine make to achieve top level of bump.
Accuracy is density of sampling.
ZodiaQ
Post by ZodiaQ » Tue Apr 30, 2019 10:31 am
There is no K3Displacement shader (at least not here) ..... ?
