K 3.01 official release
Post by Janusz Biela » Tue Jan 15, 2019 1:01 pm
Official release K3.01
log:
Code: Select all
3.01
- optimized geometry memory usage
- faster ray cache build
- experimental fast scene import
- new tanH tone mapper allows to control shadows and bright areas contrast
- post processing (including tone mapping) real time preview
- Kray3Output now allows to save or resend last rendered image
- bug fixes:
	 ID map cycle
	 Unseen through glass not working
	 Save image without extension
New options
1. New tone mapper TanH:
https://www.desmos.com/calculator/qanvydl29q
Later we will add this curve to GUI.
2. Real time tone map. To achieve this option (VPR still is under developing) you must finish render.
Simple open after render Tone map option:
and from now you can change values and see what is effect of that in K3 render window.
3. New Output options:
Where:
- Frame buffer open (if you closed) K3 window render. K3 store all data in memory include GI.
- Send to LW - it send actual buffer (render) to LW window
- Save - you can save image directly.
4. New Loader: Turbo/Fast/standard
Default in Kray is standard mode because G. still develop Turbo and Fast mode.
You can activate them from command line if you want test it:
TURBO
Code: Select all
sett debugTestValue,0,2;
FAST
Code: Select all
sett debugTestValue,0,1;
STANDARD
Code: Select all
sett debugTestValue,0,0;
is default in Core right now.
Example:
bounce lights 40 and Fast mode
sett recurse 40; sett debugTestValue,0,1;
Turbo mode is incredible fast loader. The difference between standard and turbo is like 3-4 min to 5-20 sec! when scene contain a lot objects.
In some cases scene can crash or freeze but you can tested it.
promity
Re: K 3.01 official release
Post by promity » Tue Jan 15, 2019 4:23 pm
Great news!
ZodiaQ
Post by ZodiaQ » Wed Jan 16, 2019 10:34 am
Photometric lights not yet supported? (11.6.3 crashes) (i moved this question to bugs section)
thomas
Post by thomas » Wed Jan 16, 2019 10:58 am
Quick interface request: could we also have slider buttons for the exposure values?
Post by Janusz Biela » Wed Jan 16, 2019 1:40 pm
thomas wrote:Quick interface request: could we also have slider buttons for the exposure values?
Can be but G. must optimize system - now is lagging.
ZodiaQ
Post by ZodiaQ » Thu Jan 17, 2019 4:23 pm
The one thing I miss is a surface pick option in the VPR window like the Shift click in LW VPR
Post by Janusz Biela » Thu Jan 17, 2019 6:39 pm
AVLKray wrote:The one thing I miss is a surface pick option in the VPR window like the Shift click in LW VPR
..on the list...
