K3 RC5 official release
Post by Janusz Biela » Mon Feb 12, 2018 2:07 pm
Official RC5 in download section
...I think we over-jumped RC4 :oops:
Code: Select all
History:
3.0 RC5 12-02-2018
- CPU load balance fixed
- initial LW2018 version (we are working on integration of new light/surfaces/volumetrics models)
- Bugtracker fixed:
	Spherical Light Noise
	not visible complete precompute map
	Strange behavior of photos
3.0 RC4 29-01-2018
- Bugtracker fixed:
	PPM reflection balance
	not completly cleaned PM solution after render
	K3 script error
	QMC sampling noise
	refraction blur noise
	smoothing error
	Crash when open plugin
	Sequence issuse stop
	Freeze after Esc
	Crash from changes in Modeler
	Layout update issue
	Crash when Physky activated
	6x1 box panorama
	HDRi freeze render
	subpatch level refresh
	noise from clip map
	cleaning PM issue
	hot photons
	white dots
	Crash in last pass render
	instant crash when Time Interpolation
	unseen not working
	long caustic calculation
	double side cause error
	Motion modifier not working
	slow reverse tracing phase
	Disabled Autophotons cause no photons
Please send me any bug information (can be not stripped - I will prepare for bug tracker)
Some problems I know but they are not important right now.
Here are universal settings for interiors.
Usage is simple:
- load items from scene
- select all K3 plugins (sorry but GUI is not yet consolidate)
- do not change anything
- press render
setting.lws
(38.46 KiB) Downloaded 75 times
If your scene is small - change GI resolution from 300mm to 100mm
If you want fast render (more noise) instead FG Rays 200/0 use 100/0 or 50/0
If you very fast render (less passes) use FSAA G2 instead FSAA G4.
These all will be soon under preset buttons with simple GUI.
promity
Re: K3 RC5 official release
Post by promity » Mon Feb 12, 2018 2:37 pm
Great step forward!
What constraints are relatively LW2018?
Post by Janusz Biela » Mon Feb 12, 2018 2:53 pm
promity wrote:Great step forward!
Because LW2018 has new features and also changed SDK , G. need prepare exporter. He works now on this. Of course it will be full supported 8)
There are new lights which G. also work on it.
Include K3RC5 release is K3 LW2018 plugin but do not use it yet.
vgabex
Post by vgabex » Mon Feb 12, 2018 3:47 pm
Spherical light's noise: much cleaner and faster than RC4! Well done!
Post by Janusz Biela » Mon Feb 12, 2018 4:18 pm
vgabex wrote:Spherical light's noise: much cleaner and faster than RC4! Well done!
We can do nothing right now with Spherical Lights.
The worst scenario for spherical light is REVERSE PHOTONS (very small distance between surface and light) this affect a lot noise.
G. optimized a lot and now I think is much better than K2. We will see this in LW2018 and after VCM implementation.
Now to reduce noise we have to increase Luminosity Rays (for example 200/0 or 500/0) in quality tab. This is also for background quality.
thibault
Post by thibault » Tue Feb 13, 2018 10:57 am
Good, nothing work !
LW 2015, ask Kray plugins, and "Cannot acquire "LW image List 7"global !
LW 2018.0.01, at opening, all is good but when i click want to do something in Kray menu, immediatly crash !
promity
Post by promity » Tue Feb 13, 2018 12:01 pm
thibault wrote:Hi,
:shock:
thibault
Post by thibault » Tue Feb 13, 2018 12:05 pm
:oops:
Alexis
Post by Alexis » Tue Feb 13, 2018 12:58 pm
Hello,
I have an old bug again concerning object import.
I import an object and render frame, no object in render.
I import the object, save and leave lightwave, restart lightwave and launch the rendering, the object is there.
In lightwave 2015.3
Post by Janusz Biela » Tue Feb 13, 2018 2:29 pm
Just said it: do not use LW2018 K3 plugin.
Simply replace old files.
Alexis
Post by Alexis » Wed Feb 14, 2018 12:38 pm
It's Ok, after delete all common folder.
Thank's ;)
Any parameter idea for exterior render with bush, grass, bird, flower ect... ?
brownie
Post by brownie » Wed Feb 14, 2018 1:58 pm
Nice !
Is it production ready, or do we have to still consider it as a beta ?
Post by Janusz Biela » Wed Feb 14, 2018 2:38 pm
brownie wrote:Nice !
We just started.... :mrgreen:
Engine Render is nothing today without real time tone map and post process + shader system.
But the worst is done, from now G. start adding features - they are easy to do.
promity
Post by promity » Thu Feb 15, 2018 11:14 am
K3RC5 is constantly falling. Even on the most simple scenes. Regardless of the settings from Janusz or with my own.
Post by Janusz Biela » Thu Feb 15, 2018 12:02 pm
Do this:
- create K2 folder for K2 PLUGINS
- create K3 folder for K3 plugins
- delete all K2/K3 plugins from computer
- put K2/K3 files to folders
- do not use LW2018 K3 plugin ( Do not keep plugin on computer)
What version of LW you use?
